Originally Posted by JacobAziza
I don't remember who it was, or what the post topic was, but somebody on this forum once claimed that high tire pressure does not in fact adversely affect braking distance (on a smooth dry surface) as is commonly assumed.
I only assumed based on my experience with bike tires. Now that you mention it, I'm not surprised if braking distance is not negatively impacted.
Originally Posted by BamZipPow
One of the things I found out with running max pressures on my LT tires were that when it came time to unmount them from the rim, the bead ended up tearing from the tires. I never had them unmounted from when I bought them brand new 3 years ago. Something to think about if you git a flat and they have to patch it...you might end up buying a new tire. ![Wink](/forum/images/smilies/wink.gif)
I'm not buying a new tire if they destroy it while I am within the pressure ratings. I'd probably lower the pressure before I came in anyways, just to give them less to lecture me about.
