Old 12-18-2010, 06:35 AM   #14 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by robots4joey View Post
whoops, thanks...
So my question I guess is: are the B381 tires better than those Insignia SE200 tires?
I hope by now, everyone who looks through these pages realizes that you have to be very careful when comparing tires for Rolling Resistance.
1) You can not compare tires tested in different sizes, at different times, unless you are sure they've been tested to the same test conditions - and even then, you should be comparing Rolling Resistance Coefficients (RRC), not Rolling Resistance Force (RRF).
2) There may be EXTREME differences between tires within a tire line - some due to some tires being supplied as Original Equipment (OE) tires. The Bridgestone Insignia SE200 is a good example where the UTQG values varies between 560AB (pretty good treadwear value, but probably poor RRC) to 380BB (and because both the treadwear and traction values are low, I'm guessing good RRC and the test data bares this out!) Another example would be the Bridgestone B381 - which only comes in 2 sizes and the UTQG treadwear ratings are different.
So to answer Joey's question:
a) If the tire size you are looking for is either 185/65R14 or 185/70R14, the BS B381's are going to give you better RRC than the BS Insigna SE200. Just be aware that many folks have reported poor wear and traction.
b) If the tire size you are looking for is 195/65R15, then the BS Insignia SE200 would be a good choice. Just be aware that many folks have reported poor wear and traction.
c) If the tire size is something other than the 3 mentioned above, you might get better RRC looking elsewhere.
The Following User Says Thank You to CapriRacer For This Useful Post:
robots4joey (12-20-2010)
