You're definitely starting with the right mods. Also consider adding a warm air intake of some kind.
Reading through the 100+ hypermiling tips (tabbed above) is another good place to start. Recently I've started shutting off my engine more at stop lights and that small change alone probably gave me a 5% boost in fuel economy. Double check to make sure your car is flat-towable (the owners manual should clarify this). If it is, take advantages of coasting where you can. An automatic is not a death sentence to good mpg; it just makes 20-30% over EPA more common than the 30-50% you can obtain with a standard.
