Sounds like you know what you are talking about.
Can you tell what is VSS voltage and what is TPS voltage, so many can follow and contribute.
Thanks a lot!
Old Beaver
Originally Posted by metroschultz
If you hack the cruise for MPG it may be easier on the input end to use TPS voltage instead of VSS volts.
This would allow constant throttle instead of constant speed.
Let me know how you do.
I am not a good hack but I can follow instructions.
Thanx,
S.
