Nice looking ride. Dig the fins on the back and the sloping rear window! It's a 4 door too so everyone can get in and out easy.
Guess I'll swap out tires and run it then. Only other mod I'd like to do is an electric fan conversion if keeping it mostly original. Stock metal flex fan is basically worthless. Wire in a relay controlled by a thermo switch with a delay and manual over ride.
Need to keep my eye out for RWD turbo diesel engines that can provide good mpg. But am unfamiliar with what I should be looking for.
Other option is to replace the rotary in the '83 RX7 It still runs, but am only an apex seal away from a swap.
VT247
