Thread: sc1 aero mods
Old 12-20-2010, 09:44 PM   #3 (permalink)
arcosine
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
No, just regular 4mm stuff from the sign shop, about $ 23 for a 4x8 ft sheet. The grill is blocked mostly, and in winter it is just a hair above 1/4 hot. There are pictures posted of the rear of the pan. Hotmelt gets brittle in 7F weather and i lost a skirt on the way to work the other day. Now it has screws holding it.
The black coroplast is about 6 to 7 years old, I took it off the old wagon and reused it on sc1, so its seen at least 6 winters. It didn't hold up so well near the muffler so I put some aluminum sheet there. Under the engine, it sagged and curled up. I had to cut openings to change the oil. I think the rear pan has more effect than the front pan, as I noticed a bigger increase in coasting with the rear on.
You can see the hitch in the photo, it hangs down below the bumper. I would like to raise it up into the bumper.
You can form coroplast with a hot air gun.
