Originally Posted by Dwffy
Hi there
I am interested in you circuit sounds like it could work for me too. What I need to know is how to instal a buck boost to go higher in voltage. Do you have a diagram for this circuit, it would be appreciated?
Thanks. Doug
Hello Doug,
The design that is currently being worked on is a Boost type PFC power supply. It takes 90-260VAC and while power factor correcting it, boosts the voltage to 400VDC and stores it in the bus.
I will try and get the schematics posted this week.
-Adam
