ChazInMT:
greetings! Call me when in Wroclaw!
Now your loved Wro is heavily snowy and jammed, waiting for majour highway detour around the city.
Pivo:
Wife Approval Factor [WAFfen - in German
> since you keep your speed down, how do other drivers react?
How do I react? - better to ask. After a trip from Kłodzko to Wrocław [120km] by old bus with stable 50 km/h I can drive on legal limits without guilt
The key for me is not the speed but fluency of transition - how drive to make it more fluent, making nedded changes in advance for example if slowing - have the car do it by itself. in a slow traffic - have a cushion rolling on, not aligning with stop-start manner.
i thought 'bout engine blanket. The front openings close makes the same [thermically to the entire engine compartment], but block the radiator cooling power. I expect the blanket can heat the engine making cooling possible - giving more heat range [more stable temperature], especially cherishing the "small routine" of engine coolant [with thermostat closed].
