Old 12-22-2010, 02:13 PM   #7 (permalink)
JasonG
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
If you can turn the fuel pressure up or swap bigger injectors, then reduce the mg/stroke of the pump it will help. If the pump isnt that adjustable, a bit more boost will help.
A full underbelly pan and axle wing/deflector should work.
Under belly pan... - Page 7 - Toyota Forums :: Toyota Nation
I never knew thew were underpowered, guess I assumed they had big Diesels.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
