Old 12-23-2010, 06:35 PM   #18 (permalink)
redpoint5
90 day: 43.3 mpg (US)
Originally Posted by bestclimb View Post
If it's yellow keep it mellow, brown flush it down...
I have also seen toilet lids that are also a sink. water filling the tank is routed up for you to wash your hands with then fills the tank.
two layers of clothing, a thin close to the body layer that is washed every time worn, and an outer layer that is washed when dirty.
I don't think I'll do the mellow yellow thing because of the smell. I will admit that I prefer to do #1 outside and take every opportunity to do so. It's a messy affair for a man to do his business into a bowl of water, so that is one of the reasons my preference is outside. Also, I was raised on a lot of property, so naturally I relieved myself wherever I happened to be at the moment.
I wear white tee shirts as an undershirt for most everything. These I use once before washing, and the outer shirt I will wear 2 or 3 times before washing. My method is to hang freshly cleaned cloths on a white hanger, and already worn cloths on a blue hanger. After wearing the garment from the blue hanger, I toss it in the hamper to be washed. So far no complaints of smell, but then again my odors are relatively tame compared to most.
Insulating hot water pipes helps reduce the amount of time it takes to get hot water flowing.
Or, you can install a brass pump that recirculates the tepid water from the hot pipes back through the cold water pipes...
If you are purchasing a dishwasher or clothes dryer, there are units that use far less water:
I will look at my insulation next time I crawl under the house, but the pump idea sounds spendy and would waste more heat overall than just allowing the water to go tepid. I would not conserve water at the cost of having to spend more on heating.
