Old 12-24-2010, 10:12 AM   #1 (permalink)
moTthediesel
Turbo Lurker
moTthediesel's Avatar
VonBondo - '65 Porsche 356SC Coupe
diesel - drive by EGT?
I've been wondering for some time -- how much should you rely on the EGT to select gears when driving for max mpg?
Of course I know that for the most part, the highest gear you can drive in smoothly will yield the best efficiency, but when watching the pyrometer while climbing hills - I sometimes wonder.
For instance, say I'm climbing a fairly steep hill at 55 mph - I can stay in top gear (4th in my case) and the engine will not be lugging, but it may be showing 900 F on the gauge. I could shift down to 3rd, maintain the same speed, and the EGT would drop to 600 F.
So is the EGT reading a reliable measure of how much fuel is being burned? Or - does the reading go down in 3rd just because the engine is breathing more and cooling the combustion chamber, even though more fuel is being burned?
