Old 12-24-2010, 05:52 PM   #1 (permalink)
Tygen1
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
New Wheels, Tires and Revised Skirts etc...
It's been a while since I've posted up anything about my car, so I figured I'd show some of the work I've recently accomplished.
The cars economy was getting worse and worse, the tires were quite worn, alignment out of whack, tie rod ends worn etc... So I parked it on the patio for a couple weeks and started work.
ID:	7548 Click image for larger version
First up the front suspension rebuild, new ES bushings were used to replace the 281,000 mile worn ones along with new ball joints.
ID:	7550 Click image for larger version
ID:	7551 Click image for larger version
Next was a A/C and Power Steering Delete with a Rack De-Powering and new inner and outer tie rods.
ID:	7552 Click image for larger version
Then a little headlight polishing.
The tires were quite bad,
So I got some 10.60lb Mazda Miata BBS and Bridgestone RE92 in the 165/65-14 size. Lost a total of 13 lb's per wheel and tire combo!
ID:	7557 Click image for larger version
Name:	DSC01104 smaller.JPG
ID:	7565 Click image for larger version
Timing Belt was a bit rough so it was replaced.
Next the Front Air Dam was rebuilt along with the Rear Skirts and finally the car was back on the ground and ready!
ID:	7560 Click image for larger version
ID:	7564 Click image for larger version
Name:	Copy of IMG_2473.JPG
ID:	7561 Click image for larger version
ID:	7562 Click image for larger version
The Following 5 Users Say Thank You to Tygen1 For This Useful Post:
BabyDiesel (11-17-2014), NeilBlanchard (12-25-2010), Nevyn (12-30-2010), Piwoslaw (12-26-2010), raylit20 (12-24-2015)
