Old 12-26-2010, 01:38 PM   #34 (permalink)
mnmarcus
Originally Posted by Cd View Post
Assuming you are getting around 4 mpg, and If your current Cd is around .75, and you decrease it by 60%, ( to .30 ) you would only boost your mileage by just over one mpg at 50 mph.
At slower speeds, like this vehicle is capable of it would be even less.
What? Oh wait a sec. 1 mpg is a 25% increase in FE... Even then, I wonder what numbers you are using???
From Unimog links:
Width 78.8 inch/6.57'
Height at highest point 105.5
Ground Clearance 17.5 inches/ 105.5-17.5=88 or 7.33'
Weight 7,920
FE 13 mpg
FA (?) 48.18 sq. ft , EE .19, drive train efficiency .9, #2 diesel
CRR (?) .015
Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
Gets 13mpg @~37mph... close to 50:50 aero and rolling resistance.
I got 9.36 mpg at 50mph with .75 Cd and a 66:34 aero to rr (respective)ratio. At .30 Cd I got 15.5 mpg, a 65% improvement in mpg and a 44:56 aero to rr ratio.
I stand by the fact that aero improvements are almost always beneficial. Would adding another axle to this vehicle cut rolling resistance by a lot?
