Either way, your light bulb is working mostly as a heater and to answer your question directly, a 100 watt light bulb will put out roughly 2.5 times as much heat as the 40 watt bulb.
If you go with a hotter bulb you might think about getting a thermostat as well as insulating, that way you don't cook the crabs.
