Old 12-28-2010, 04:15 AM   #4 (permalink)
pounsfos
Laura the Lancer - '81 Mitsibishi lancer LX
Originally Posted by Ang84Indy View Post
Thanks for the link, I've never heard of these alternators.
But, the Eco-Tech appears to be overkill for a car. The size would be difficult to manage, and at 38 pounds it is much heavier than any automotive alternator. If I were to adapt a new alternator, it would be a General motors CS130. It weighs 10 pounds, and the minimum output (depending on model) is 100 amps, more than your stock alternator.
yeah that website was an example...
and saand:
mine is a 45amp brush one with steel cooling fans connected to the belt drive. so there is room for improvement.
remember 10 mods netting 1.5% better fuel economy each all add up in the end .
this is my new project for next year im going to make a decent alternator
if you changed your alternator to one that is a higher amperage will it have to run less often or will it be about the same??
