Old 12-28-2010, 08:54 PM   #8 (permalink)
RJVLER
I in agreement with the rust concern - but I think if the hole was treated properly and then a stainless nutsert inserted in the whole ( It goes in similer to a big rivet and mushrooms on both sides )that the stainless pin slides into should solve the problem. The nutsert could then be undercoated for more protection - Then all you would have is a stainless hole going through. I will give it a try and see how it goes. And I will repost and see what you think and keep corrosion in mind all the way. Im glad you mentioned it as I here in Oregon wouldnt have fought that as bad. Thanks John
