Old 12-29-2010, 11:52 AM   #131 (permalink)
jackbauer
jackbauer's Avatar
First thing i'd say is to take a few pictures of the inside of your charger so we can see how it operates and maybe diagnose the problem and/or point out a few tests. I seem to remember from your videos that its a Lester? If so it will be something like a simple scr rectifier so should not be a big deal to repair.
The ideal plan would be to have the genny charge the pack directly and vary revs acording to load. This means you don't use a charger at all but use the engine rpm to regulate the output. I'm aiming for something like this but mounted on a trailer. It all depends of the design of the generator. Does it change speed to match loads? Ie if you plug something in does it increase rpm?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
