Old 12-30-2010, 09:54 AM   #4 (permalink)
nemo
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
I am not a mechanic just a tinker.
Today, my check engine light came on. (The car is a 2000 Toyota Corolla.) After bringing it to my mechanic, I was told that it was the code for the catalytic converter. He said that it could possibly be the oxygen sensor, so since he would replace both anyway, I should try replacing the sensor first, and see if that alone would clear the engine light.
That is the problem OBII codes. They don't always tell you what to replace. But what the system "thinks" the problem is. If a sensor is reading incorrectly it may indicate a different problem an O2 sensor indicating a cat problem. This is were a good & trusted mechanic comes in. He must make decisions, do I replace the part or or spend the time trouble shooting, which is more cost effective.
The advice he gave is quite reasonable in my opinion, based on just doing a code check. You didn't state how many mile are on the car if your car is routinely maintained. My self I usually just reset the code and see what happens, the proceed.
The Following 2 Users Say Thank You to nemo For This Useful Post:
carwhat (12-31-2010), Xist (08-21-2017)
