Originally Posted by carwhat
So, you think it's ok if I just ask the mechanic to shut the light off and ignore it? Does the light keep coming back on?
Unless you have the ability to get into the computer code and shut off the oxygen sensor ( I presume this is the 2nd sensor that tattles to the computer how well the catalytic converter is doing to clean the air ) the code will keep coming back.
