Old 12-30-2010, 06:43 PM   #4151 (permalink)
jpirkola
Originally Posted by duncan View Post
Hi Guys
I have my Christmas present (controller kit) and I am plucking up the courage to start work.
Don't worry as long as your soldering skills are good, it will go well. I just finished assembling my kit and then learned something after the fact. Paul may have already notified you of this, but better to be safe. Check with him anyway just to be sure.
The heat transfer material you put between the heat spredder bar and the mosfets or diodes has peeloffs on both sides. It's not really apparent (at least it wasn't to me).
It's a fairly easy fix I'm told and it does look that way.
Hope this save you some time.
Jim
