Actually, if you're burning that much oil there is a good chance the Cat actually is damaged, whether that matters is up to you, if it passes it passes. My code is indicating a fault, but it is actually the sensor being a baby.
If you turn it off, it will likely come back on if something is actually wrong. Cat's don't fail unless something else is going wrong as well.
