Old 12-31-2010, 12:25 PM   #2 (permalink)
ceej
ceej's Avatar
Box - '99 Chevy Metro Base
Transit - '10 Ford Transit Connect Van XLT
90 day: 23.2 mpg (US)
The 190° thermostat would be the right choice.
My 1994 FSM calls out for a 190°. Always use the correct one for the cooling system design wherever possible.
The XFI used a 197°F thermostat. That is likely the "Replacement" you got.
180° is not appropriate. Fuel consumption will be higher, and power lower running at a lower temperature.
The 195° thermostat will likely work just fine.
CJ
