Hello Ryland
It's a 2000 non-turbo diesel.
I'd probably need some form of power steering as the engine is in the front and it weighs as much as an elephant. I was just asking which is more efficient: hydraulic or electric power steering. I found a post here that says electric is more efficient as the hydraulic system is always being run whereas the electric system is only 'on' when you turn the steering wheel. That's good to know, I just have to work out the cost/benefit ratio and find somewhere that sells the conversion if it works out favourable.
Yes, I will see what size wheel I can get away with (larger the better) after the suspension upgrade. Currently 15" wheels with 65 tyres (stock) but I may go to 16" thinner wheels and lower profile tyres. I've found WheelWeights dot net as a good source of weights for a large range of wheels. I need to find the same for tyres.
Cheers, Steve
