Old 01-02-2011, 11:33 AM   #137 (permalink)
jackbauer
jackbauer's Avatar
Yeh the thin wire is the gate. If you disconnect the gate you can probably test the scr in situ with a meter. This page has some good information and diagrams:
The Silicon-Controlled Rectifier (SCR) : THYRISTORS
Depending on the device you can wire a resistor between the gate and anode and it will fire manually. This would at least prove that the scr is ok and the problem is in the firing circuit.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
