Thanks again
LC, the holes were there, I didn't drill a single hole.
All I did was to pick the hoes that aligned wll with my pieces and stick a bolt through them.
Most cars have extra holes in the sheet metal, especially around the engine bay.
Aerohead, the dam extends to right about 8.5" off the ground which lines up with the crossmember's height (the one under the motor).
It's also about the same on the bumper of my wife's Prius, so I take it as a good gauge for driveway approach angles and such
This basically does not increase the frontal area at all but does block a good bit of air flow to the suspension arms (they didn't need cooling anyway
As an interesting note, I have yet to hit the half mark of my fuel gauge at this point, and I'm well passed the mileage that I used to get there.
Seems like the bumper works well.
Moti
