boken timing belt?
Jim-Bob is correct "Normally you test a car with all three plugs out, throttle wide open, coil wire pulled, and with a fully charged battery."
Did you notice "throttle wide open" That is the step most forget.
"0 lbs" all three cylinders my bet is a bad gauge or possibly a broken timing belt.
tom
