Old 01-03-2011, 01:28 AM   #6 (permalink)
alohaspirit
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Originally Posted by Old Mechanic View Post
Be careful with blocking the grille on a car with an automatic transmission. If you reduce the transmission coolers effectiveness you could overheat the fluid and possibly damage the transmission.
That may not be an issue in your case if you are not driving longer distances at higher speeds.
regards
Mech
Will monitoring the engine temp via scanguage be enough?
Past Present Future?
