Originally Posted by Weather Spotter
Yes, that should be enough. If the fan comes on too much then reduce the grill block.
Personally, I have a feeling the heat will go up
(tropical weather after all)
Originally Posted by CigaR007
No pressure. Besides, I intend on finishing the lower grille block installation on my ECHO tomorrow. The upper grille block has been on for a few days already. Should report my findings soon enough.
Sounds good. Im interested in how you made your grill blocks.
How are those miata rims treating you?
