PaleMelanesian -
Originally Posted by PaleMelanesian
If you're planning $1200 in mods, you should definitely consider the 150 for a Scangauge. It'll help you save as much gas as all the other plans combined.
Yes yes yes. The SG also gives you OBD II error code access, which can cost up to $80 as a separate (and less useful all-by-itself) gizmo. Since the SG is portable, you can use it to help your pals when they get SES lights in their cars. The e
Xtra gauge info is cool too.
CarloSW2
