Old 01-03-2011, 05:20 PM   #26 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Arragonis View Post
Er, probably not
Are you ashamed of the numbers maybe ?
If you do a remap get one of those boxes where you can revert back to default if you need to - just in case.
The remap boxes to fool the ECU aren't very efficient.
If it's going to be done, I'm getting the Rica E-power (software) upgrade which is designed for lower fuel consumption.
I don't want HP @ high rpm anyway, and I don't want to push the gearbox too hard with 300+ Nm as it's a known weak spot.
