Originally Posted by jason1973tl
Tell me your opinion, how does it look and what would you change if anything?
What's the front of it ?
There's no aerodynamic need for pointy ends on the front.
A blunt front (using the aero-template) also gives more internal volume, and you can use more of the rest of the car's length to closely follow the aerotemplate.
Or you can make the car shorter (and therefore lighter).
You get most of the benefits from the aerotemplate's shape even when you abruptly cut it short using sharply defined, straight edges (i.e. a real Kammback).
Making it even shorter and lighter.
