Old 01-03-2011, 11:43 PM   #8 (permalink)
SentraSE-R
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I own both the Scangauge II and Ultragauge. The SGII has some advantages if you have a Prius, and/or if you want to monitor something unusual, like transmission fluid temperature and you know the coding necessary to display that parameter. You'll spend hours just programming and testing the xgauges that work for your car.
The UG is much more usable for a beginner, and for the vast majority of people who aren't into programming xgauges. Instead of tedious SG programming while guessing which OBD-II communications protocol your car uses, you plug the UG in, and it recognizes the protocol within seconds, and displays the available standard gauges that most of us use.
Bottom line: if I were to buy one tomorrow, for myself or as a gift, I'd buy another UG. It's less than half the price of the SG, looks better (much more modern display), and displays six parameters per screen, with three screens available. The SG shows only four parameters. With the UG, if I want to display g/h, distance to empty, and avg tank mpg, and they're not on my main screen, one push of a button and they're all on my second screen. With the SG, I have to cycle through the dozen or so standard gauges and 24 xgauges each time I want to change just one of the four displayed parameters. That's 20 or so button pushes to get to g/h, and another 20 or so to get to DTE - tedious stuff.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
