Originally Posted by t vago
Have you thought about using one of them demand (or instant) water heaters? I first encountered them when I rented a house in Japan, then another one when I rented an apartment in Italy. They're wonderful because they give heat almost instantly, they never go cool on you, and you're not having to continually heat up 30 or so gallons of water that you may not be using at the moment.
They are used mostly in situations where hot water is not needed every day, or where space saving is above all else as the energy savings from the on demand hot water heaters tends to take the 20 year life of the water heater, add to that the acid flush to keep it functioning properly and it's a net loss.
