Thread: Spark plugs?
Old 01-04-2011, 11:51 PM   #6 (permalink)
stovie
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
From what i understand the hotter the spark the quicker the flame front in the combustion chamber and therefore more power and fe because the ecu has to reduce fuel to compensate for the increased burn speed(the engine can't handle an instant explosion to much force on the piston/rod and it can only move so fast) And the fine tip'd iridium spark plugs are better i think because they allow more vapor around them to increase the burn rate also. You might get better results with a higher voltage coil.
