Old 01-05-2011, 10:04 AM   #4 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by abently View Post
The RPM's can't be the same, because say you use 8Kw of power to cruise at 60km/hr, that 8Kw of power at 14.7:1 occurs at say 1500rpm, and at 17.7:1 occurs potentially at 1700rpm. Therefore shifting your cruise rpm into a lower bsfc zone.
Most engines are putting out more power then needed at cruising speed tho, so say your car requires that 8kw/10hp to maintain speed, the engine is most likely putting out closer to 12kw/15hp, so with a lean burn engine you keep the same engine speed but cut out some of the fuel so it run leaner, you get a drop in power but it's a low load condition so you don't need that power.
