Old 01-05-2011, 04:40 PM   #4169 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Thats correct Joe.
If you have gotten the chip from paul, it should have the bootloader and a version of firmware already on it. If you bought it from digikey, you will either need to build or buy a programmer to get the basic program on the chip. If you search this thread for pony prog you will find some info. it might also be found under pony-prog.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
