Old 01-06-2011, 01:33 AM   #41 (permalink)
stovie
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
Any1 try induction heating??? might do more for the same wattage, instead of heating 1 spot u could position it to heat up more area but it would only work on steel of course...... Oh heres somthing i read about, if u take two cans just big enough for 1 to fit inside the other and then run a zinc rod down the middle and feel between the cans with moter oil and then connect a drill to the zinc rod u can hit about 165F in like 30 seconds and the bigger the cans the faster they heat up maybe use that to heat the motor.......if it works of course???
