Hopefully this directly linked image is visible to others.
It shows one of our controller boards on the bench reporting to a ScanGauge over CAN bus. The four values on the screen are RPM, throttle position, voltage and temperature.
The adjacent industrial panel meter is reporting the RPM measured from a separate sensor. It's actually reporting RPM/10 to get a faster display update rate.
