Originally Posted by abently
Otherwise how/why do all other Lean-burn engines operate in the 20-25:1 AFR's?
The other engines you mentioned have direct gasoline injection. This enables them to do neat tricks, like inject just enough gas to make a super-lean mixture during induction, and inject a little more gasoline later on to create a stoichimetric pocket of air-fuel mix within the super-lean mixture, during compression. This gives a so-called stratified charge. The spark plug easily ignites the stoich pocket, and the burning pocket then goes on to reliably burn the rest of the super-lean mixture.
That's how you can get 20:1 to 25:1 AFRs with modern lean-burn engines.
