It sounds like the fuse bits need to be changed. The default frequency of the chip is 1 MHz I think. But it should be 16 MHz. Make sure it's extended high low of F8 DC F7. The blinking light should be about 10 times per second, but since the chip is running 16 times slower, it blinks at about every 1.6 seconds.
