Jevon's paradox
In economics, the Jevons paradox, sometimes called the Jevons effect, is the proposition that technological progress that increases the efficiency with which a resource is used tends to increase (rather than decrease) the rate of consumption of that resource.[1] In 1865, the English economist William Stanley Jevons observed that technological improvements that increased the efficiency of coal-use led to the increased consumption of coal in a wide range of industries. He argued that, contrary to common intuition, technological improvements could not be relied upon to reduce fuel consumption.[2]
The issue has more recently been reexamined by modern economists studying consumption rebound effects from improved energy efficiency. In addition to reducing the amount needed for a given use, improved efficiency lowers the relative cost of using a resource, which increases demand for the resource, potentially counteracting any savings from increased efficiency. Additionally, increased efficiency accelerates economic growth, further increasing the demand for resources. The Jevons paradox occurs when the effect from increased demand predominates, causing overall resource use to increase.
The Jevons paradox has been used to argue that energy conservation is futile, as increased efficiency may actually increase fuel use. Nevertheless, increased efficiency can improve material living standards. Further, fuel use will decline if increased efficiency is coupled with a green tax that keeps the cost of use the same (or higher).[3] As the Jevons paradox applies only to technological improvements that increase fuel efficiency, policies that impose conservation standards and increase costs do not display the Jevons paradox.
Jevons paradox - Wikipedia, the free encyclopedia
