Old 01-10-2011, 01:13 AM   #21 (permalink)
Frank Lee
I've gone larger on the F150 and it did NOT work, but then again, mine has the tallest axle gears available. With the oversized tires it downshifted every time someone sneezed, and it gets driven on the flatlands. Since yours is also a '94, it likely has the E4OD transmission. If you have the tall gears you will not like all the downshifting.
