Decelerating in neutral at 140km/h with the engine running I saw a reading of 292mpg in my old Pontiac Vibe.
On flat ground with a steady throttle at freeway speeds I can keep the instant mpg reading from jumping more then .2mpg.
I found that with my winter tires I had to up the EFF number to 93 to keep a relativly accurate reading.
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
