Thread: sc1 aero mods
Old 01-10-2011, 09:21 AM   #32 (permalink)
arcosine
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Antenna is a home made (and designed, on NEC) 2 meter, 3 element x 2 broadside beam, > 10 dBd gain at 5 feet above the car. (rubber neck attractor) I will be painted black and used primarily in the dark.
Neil, That looks good, I was thinking of something like that but haven't worked out how to fill the gap behind the tire without it catching the air. I have screwed in 1 1/2 inch black poly tubing around the opening which I formed into an arc in the oven using a bicycle rim. (pictures later). My current thoughts would extend the fixed part over the whole wheel well with circular slots cut 2/3 around and something elastic for tension, but maybe the top hinge is the way to go. I think that the Bonneville wheel covers won't attach to the aluminum wheels.
