Thread: sc1 aero mods
Old 01-10-2011, 01:21 PM   #34 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
arcosine -
Originally Posted by arcosine View Post
Antenna is a home made (and designed, on NEC) 2 meter, 3 element x 2 broadside beam, > 10 dBd gain at 5 feet above the car. (rubber neck attractor) I will be painted black and used primarily in the dark.
Thanks for the antenna info. That's an Arcosine-1.0, ha ha.
Neil, That looks good, I was thinking of something like that but haven't worked out how to fill the gap behind the tire without it catching the air. I have screwed in 1 1/2 inch black poly tubing around the opening which I formed into an arc in the oven using a bicycle rim. (pictures later). My current thoughts would extend the fixed part over the whole wheel well with circular slots cut 2/3 around and something elastic for tension, but maybe the top hinge is the way to go. I think that the Bonneville wheel covers won't attach to the aluminum wheels.
That's been my problem for years. I finally solved it here :
http://ecomodder.com/forum/showthrea...isk-11838.html
However, that thread is out of date. I have since simplified the parts and moved to alimuinum wheel covers. This pan has a slight gap, maybe < 1/2" :
I will publish a new thread with all the details.
CarloSW2
American Solar Energy Society
