Also, I would like to note that I looked at the PS setup for the Subaru, it would be fairly easy to cut the pipe in the straight as it comes overtop the cylinder head. Then, unclip the host going into the PS pump, loop the factory hose onto the line and seal the rack with all the fluid inside, keep the original power steering reservoir in the loop and maintaining extra fluid with room for expansion in the reservoir.
