Thread: 12V fridge
Old 01-11-2011, 12:36 AM   #2 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
First off, are your solar panels pointed at the sun or just kind of "up"?
Do you have a multi meter/volt meter that allows you to check the amp draw?
And do you know how much the fridge compressor runs?
Battery capacity is to 100% dead, using it like that and your battery might last a year if you are lucky, 50% discharge is more reasonable if you want it to last 4-5 years.
As it is I suspect you can get to 50% discharge over night if the weather is warm so right there your battery is not big enough, then you want to size your PV panels by finding your average hours of full sun per day, or sun hours, this easily seen as the number of hours per day that your panels will put out their full output, you use this number paired with your figure on your load to figure out how many panels you need figuring in battery losses as well.
