Old 01-11-2011, 06:24 AM   #12 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Arragonis View Post
I have resisted EO(ff)C so far but I may try some experiments...
Tempting, ain't it?
Originally Posted by COcyclist View Post
Arragonis, are you considering E(off) coasting out of curiosity or in the name of science? Our diesels are so much more efficient at idle than a gasser (petrol) that I haven't felt that it was worth it.
What we're after is not using less fuel, but using even less.
And if you don't have to key off (kill switch?), then your PS, airbags, etc., should still work (mine do).
If I go 'Hybrid' I understand the SG2 keeps going when the engine stops, but I suspect my calibration may be broken.
I tried using 'Hybrid' mode when playing with EO(ff)C, but in my case not only did the SGII turn off after a few seconds, but fuel consumption was total nonsense. I admit that was before I had my kill switch, so MAYBE it won't turn off if I don't turn the key, but the consumption will still be random. Also, even if SGII doesn't freeze up, it may or may not be getting all the info it needs: my factory installed FC computer doesn't register distance when EO(ff)C, but the odometer does. SGII - I haven't checked yet. I won't be driving before Saturday, and even then I'll be with the Wife, so I may not be able to do too many experiments with the engine off, but if I try something I'll let you know.
Maybe SGII needs a new mode, 'Diesel + Hybrid'?
