Old 01-11-2011, 02:31 PM   #14 (permalink)
Arragonis
The PRC.
Originally Posted by Piwoslaw View Post
Tempting, ain't it?
What we're after is not using less fuel, but using even less.
And if you don't have to key off (kill switch?), then your PS, airbags, etc., should still work (mine do).
Some mild experimentation (yes I have been tempted ) seems to suggest that PAS and brake assist goes with the engine off even with the key right round although I think the Mk1 Fabia has leccy power steering.
A kill switch sounds interesting. Anyone made one for a TDI ? (I will search in a while, just lazy at the moment...)
I tried using 'Hybrid' mode when playing with EO(ff)C, but in my case not only did the SGII turn off after a few seconds, but fuel consumption was total nonsense. I admit that was before I had my kill switch, so MAYBE it won't turn off if I don't turn the key, but the consumption will still be random. Also, even if SGII doesn't freeze up, it may or may not be getting all the info it needs: my factory installed FC computer doesn't register distance when EO(ff)C, but the odometer does. SGII - I haven't checked yet. I won't be driving before Saturday, and even then I'll be with the Wife, so I may not be able to do too many experiments with the engine off, but if I try something I'll let you know.
Maybe SGII needs a new mode, 'Diesel + Hybrid'?
Thanks, I maybe won't try the Hybrid mode given the calibration just now. The on-board comp still registers distance and therefore still calculates average MPG with the engine off.
Given these facts I'll probably keep the SG2 for tank to tank monitoring and use the on board for testing this idea out. The commute tomorrow will be the first go.
