Originally Posted by stovie
p.s. has anyone tried cryogenic processing? this guy supposedly did it to he's prius motor and went from 60mpg to 120mpg and also got 50% more power, and he's motor goes 3-5 times longer between rebuilds
I find this hard to believe. going from 200,000miles for a rebuild to 600,000 miles between rebuilds? Or 300,000 miles up to 1,200,000 miles. How would he have time to test this? Or if he did the rebuild with the cryo at 50,000 miles and he is now at 200,000 miles (the original 50,000 plus 3 times that distance) it is not an accurate assessment because 50,000 is a low mileage for a rebuild.
By just doing something to the motor to get a 100% improvement to mileage neglecting aerodynamic drag and drive train losses? At the same time increasing the power by 50% would require a massive reduction in friction...which makes some kind of sense that a restructuring of the surface of the metals could reduce friction till you realize that the metal does not really touch metal if there is oil in the engine.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
